Home » Audio » Speaker » Two horn theory papers
actual function [message #17804 is a reply to message #17799] Sun, 08 May 2005 20:23 Go to previous messageGo to next message
I agree,many horns achieve the criteria by only slight margins. They will 'work' But are nothing like the perfect infinite horns.
The reactive quality of compromised non ideal horns concerns me but they still sound alright?
[quote] So a short horn on the front of a woofer is basically a front ported enclosure.
Certainly theres a point where the horn is hardly functioning - and there is the opposite extreme where it is functioning to its maximum potential[horns no one can fit in their house]
And often inbetween many basshorns like the labhorn[in large stacks]
For my home use 42hz 2226 horn,I decided the minimum sensitivity would be 100db/1watt,below that I might as well not bother.
Id love to buy some AES-its just that I think the anthology might be more useful and practical.
regards
Mike.e
Re: Two horn theory papers [message #18140 is a reply to message #17801] Fri, 02 September 2005 12:01 Go to previous message
majestik6 is currently offline  majestik6
While I don't need the papers myself, because I have your books and the AudioXpress AES books, you can definitely download them online. A google search will turn them up in .doc format.
Previous Topic: Bypassing speakers transformer
Next Topic: Why do they cost so much??
Current Time: Mon Nov 16 06:20:50 CST 2026
