Home » Sponsored » Pi Speakers » Skywave's 3 Pi Build
Re: Skywave's 3 Pi Build [message #75576 is a reply to message #75575] Wed, 20 February 2013 11:58 Go to previous messageGo to next message
Thanks, Wayne,
I went with the conventional way because I wanted to try out my new mini drill press before I have to pack it up. I'm also an old dog, so...
I think I will use little mini wood standoffs, glued into the cab, then I'll screw the board onto that.
Re: Skywave's 3 Pi Build [message #75577 is a reply to message #75576] Wed, 20 February 2013 12:07 Go to previous message
Should work very nicely, I think. Just make sure you have enough support, especially under the coils. Might add extra wood supports or cushion with rubber supports in-between mounting holes and under heavy components.
Previous Topic: Buffer for my system?
Next Topic: 2Pi's completed - now I want a center channel
Current Time: Sat Oct 24 16:20:12 CDT 2026
