Home » Audio » Thermionic Emissions » Something new on the bench
Re: Something new on the bench [message #85631 is a reply to message #85630] Thu, 13 July 2017 20:23 Go to previous messageGo to next message
I really like the 6550 / KT88 tubes. And with what Bruce has found on the larger tubes, that makes it even more of a sweet spot for me.
Re: Something new on the bench [message #85646 is a reply to message #74921] Mon, 17 July 2017 15:28 Go to previous message
I like the kt88 tubes as well.
I would think the current troubles with the kt120's will pass.
Is TUNG-SOL the only current manufacturer?
I have decided to go ahead with a pair of OddWatt Odd Block series 2 octal using kt88s.
It looks like it should be a fun build.
I agree with you about some current SET amps being fickle.
I've had my own issues with a kit I built, started blowing fuses (after around 200 hrs.), needing a very specific rectifier tube to correct it (EH 5U4GB).
Regards!
Previous Topic: KT120 and KT150 tubes not up to spec
Next Topic: Tube on a Chip?
Current Time: Wed Nov 18 13:01:42 CST 2026
