| Delta 10's need break-in! [message #50609 is a reply to message #50608] |
Sat, 27 January 2007 10:48   |
spkrman57
Messages: 522 Registered: May 2009
Illuminati (1st Degree) |
Bill, I'm sure they will sound better after break-in(as we discussed on the phone. db: You lost me on what you were trying to convey in your previous posts. As to the different impedances of the drivers, Wayne and I have schooled Bill into what will work. I have fairly extensive experience with the JBL 2226 drivers as does Wayne. Also, we covered the many possible problems that may come up. Bill: You might consider a smallish series resistor on the Delta 10 to smooth it out also. Maybe a 4 ohm or 6 ohm to see what it does! Regards, Ron
| Re: 12 Ohms and 1.8 Watts [message #50610 is a reply to message #50607] |
Sat, 27 January 2007 11:11   |
dB
Messages: 234 Registered: May 2009
Master |
bill thanks, Speakers are different (as Wayne tell us all the time) from resistors. They change with frequency and resonance. T/S Re for the JBL 2226J = 10.0 ohms T/S Re for Eminence Delta10 = 5.42 ohms “With just a coil; way too bright.” “I put back the attenuation from the 2123: 15ohm R parallel and 10hm R series. Tamed the Delta right in line.” “ and for the woofer, I'd just use a 6.0mH coil in series and that's it.” – bill Is this your setup bill? Are you using only this 3 components for the two woofers/mid part? I'am just curious. DB
| Re: Delta 10's need break-in! [message #50693 is a reply to message #50692] |
Tue, 13 February 2007 17:04  |
I think the Eminence Delta 10 sounds very nice in the seven π midhorn. You might try it and see how you like it. The price is right.You may know that I tend to favor JBL Profesional Series woofers. The addition of a shorting ring and the build quality of the JBL 22xx woofers is much better than comparable Eminence woofers, in my opinion. But not so much with the mids. Especially since the driver is horn loaded, which reduces excursion and low-passes the overtones, tending to attenuate harmonics. My suggestion: Go with a JBL 2226 in the Profesional Series seven π bass bin. Use the Delta 10 in the midhorn. Pick your favorite compression driver and you're set.
