Home » Sponsored » Pi Speakers » Is that a
Is that a [message #50207] Mon, 30 October 2006 02:00 Go to next message
Zene Gillette is currently offline  Zene Gillette
JBL horn you use with the Eminence 2002 driver? Zene
H290 [message #50208 is a reply to message #50207] Mon, 30 October 2006 08:27 Go to previous messageGo to next message
The horn used with the PSD2002 is an Eminence H290. I've also used the Peavey CH-3 with good results. The Peavey horn has a screw-on mount, so use the PSD2002S when using the Peavey horn.
Re: H290 [message #50209 is a reply to message #50208] Mon, 30 October 2006 22:26 Go to previous messageGo to next message
Thanks Wayne... Can I ASSume you prefer the H290 over the JBL 2344 or the P.Audio 316 clone?
Zene
Re: H290 [message #50210 is a reply to message #50209] Tue, 31 October 2006 09:49 Go to previous messageGo to next message
Not necessarily. The JBL 2344 is a different animal. I've used the JBL 2370 and liked it, but the price tag is higher than Eminence or Peavey horns. To tell the truth, I prefer the Peavey CH-3 over the JBL 2370, but it isn't as attractive aesthetically. The H290 won't go as low, but at the crossover point chosen, it works very well. In the end though, all the designs have been tested with the H290, and that's probably the most important part. If you use something else, you really have to measure it yourself and fine-tune the design for the horn you've chosen.
2344 horn by JBL [message #50211 is a reply to message #50208] Tue, 31 October 2006 11:26 Go to previous messageGo to next message
spkrman57
Wayne,
The 2344 horn is the one used by JBL in their 4430/4435 studio monitors.
It is the infamous "Butt-cheeks" horn. Very interesting, I had a pair of 4430 monitors and sold them, but just found a pair of 2344 horns and will look a creating a 4430 clone.
They have great dispersion, but don't sound like most other horns.
Just to offer some horn info here!
Regards, Ron
Re: 2344 horn by JBL [message #50212 is a reply to message #50211] Tue, 31 October 2006 13:27 Go to previous messageGo to next message
Yes, I'm familiar with JBL 2344 horns. They have a little wider dispersion pattern and a lot taller. They're nice but different enough from the H290 that a redesign would be in order.
Re: 2344 horn by JBL [message #50213 is a reply to message #50212] Tue, 31 October 2006 14:19 Go to previous message
spkrman57
100 x 100 degree.
And yes, they need different crossover circuitry than most horns.
I had sold my JBL 4430 studio monitors, but just recently bought a pair of 2344A's to play with.
Ron
Previous Topic: Better port design for less dynamic compression?
Next Topic: Boxplot How To Guide
Current Time: Sun Oct 25 01:01:26 CDT 2026
