Home » Sponsored » Pi Speakers » Better port design for less dynamic compression?
Better port design for less dynamic compression? [message #50204] Sat, 28 October 2006 19:38 Go to next message
swett is currently offline  swett
JBL claims that their "Linear Dynamics Aperture" port reduces turbulence in the port and hence reduces the amount of dynamic compression in the bass range.
You can see the profile in Figure 11 in this PDF, along with a power compression graph: http://www.jblpro.com/LSR/PDF/JBL.tn_v3_2A.pdf
I'm not sure if this is something to be considered when making a port for something like a Pi speaker or if its just a matter of making your port large enough and turbulence will never be an issue?
Re: Better port design for less dynamic compression? [message #50206 is a reply to message #50204] Sat, 28 October 2006 19:47 Go to previous message
I'm not really seeing much of an issue with dynamic compression in the port. As you've said, if the airspeed through the port isn't excessive, then turbulence isn't an issue.
Previous Topic: Wayne I need a speaker recommendation
Next Topic: Is that a
Current Time: Sun Oct 25 01:00:04 CDT 2026
