Home » Sponsored » Pi Speakers » 9Pi mid-bass horn dimensions???
9Pi mid-bass horn dimensions??? [message #49985] Wed, 06 September 2006 11:22 Go to next message
I'm getting hypotenii of 41 1/2" with a 75 degree angle from the 7" aperture to the 28" mouth?
Is that close?
Re: 9Pi mid-bass horn dimensions??? [message #49987 is a reply to message #49985] Wed, 06 September 2006 16:26 Go to previous message
The midbass horn used in the 9π loudspeaker is a straight sided horn designed to be used with a 15" driver. Each wall angle is 20° so the total coverage angle is 40°. The length is 32", mouth dimensions are 28" x 28", throat is 7.5" x 7.5", front chamber is 800in3 and rear chamber is 1200in3. Here are the Hornresp parameters for the horn with a JBL 2226:
http://www.pispeakers.com/misc/9Pi_Midbass_Model.gif
9π Midbass Hornresp input screen
http://www.pispeakers.com/misc/9Pi_Midbass_Response.gif
9π Midbass SPL response
Previous Topic: Learned some more audio truth outdoors
Next Topic: Premium 4 cabinet modification
Current Time: Sun Oct 25 01:00:03 CDT 2026
