Home » Sponsored » Pi Speakers » system opinion
system opinion [message #49683] Mon, 03 July 2006 07:46 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy. Wayne .I ask for your opinion about this system . Im planning to make a system with a bass bin horn loaded from BFM design running with the round corners to work up to 500 hz then come your mid-horn designg and atop a tweeter makeup of various piezo elements all running without a croossover only acoustic croosovers .thanks for your attention
Re: system opinion [message #49684 is a reply to message #49683] Mon, 03 July 2006 09:56 Go to previous message
I would prefer a seven π cornerhorn. The crossover is designed to make summing perfect at each crossover point. You're not going to have that with the system you've described and so for that reason and others, performance will not be nearly as good.
Previous Topic: One Pi Towers in Houston
Next Topic: Inductor coil values for Theater 4 pi crossover
Current Time: Sun Oct 25 01:27:41 CDT 2026
