Home » Sponsored » Pi Speakers » Theatre 3 Pi Crossover
Theatre 3 Pi Crossover [message #49420] Mon, 01 May 2006 15:06 Go to next message
themilford is currently offline  themilford
Hey Guys,
Long time no visit... err first-time visit since the A*d!@ Asylum.
I need help. I've got a pair of K-12s that J. Lapaire built. I need to use these at our wedding. I have a pair of Delta 12LFs and a pair of PSD2002/H295s. Essensially Theatre 3 PIs.
Can I just get away with the Theatre 3 Crossover and can anybody tell me what passive coponents are used?
Wayne can I just order the passives from you?
Time is ticking... the wedding is on the 13th!!!
Cheers,
David
Re: Theatre 3 Pi Crossover [message #49421 is a reply to message #49420] Mon, 01 May 2006 17:05 Go to previous messageGo to next message
Gotcha covered, David. I'll send the crossovers out tonight and they will be there by the end of the week.
Congrats on the wedding!
Re: Theatre 3 Pi Crossover [message #49423 is a reply to message #49421] Tue, 02 May 2006 08:52 Go to previous messageGo to next message
THANKS!
I'm really excited to try these... I'll keep my fingers crossed.
I'm getting positive resposes in regards to using this x-over with the K-12s.
For giggles I might grab a pair of the Eminence x-overs as backups to try.
I'm hoping after the wedding to build a pair of Theatre 3s for the living room... the K-12s will go back to their original job as my stereo bass guitar rig
Hey, keep your eyes out for a package from Tee Pee Records... I'm sending you some music to check out.
Cheers,
David
Re: Theatre 3 Pi Crossover [message #49424 is a reply to message #49423] Tue, 02 May 2006 09:05 Go to previous message
Sounds good. If you want to try alternate configurations, just use the PCB without the tweeter compensation cable assembly and/or without the Zobel. Hook the drivers up directly to the crossover PCB. Replacing the tweeter compesation cable with a straight cable will let you know how the tweeter sounds without CD EQ. Removing the Zobel will add a peak in response coming from the woofer around the crossover frequency.
Previous Topic: Wayne - Crossover values for 2 x 16-ohm motors in Four-Pi Pro
Next Topic: Server Problem?
Current Time: Sun Oct 25 03:20:34 CDT 2026
