Home » Sponsored » Pi Speakers » 10" horn loading
10" horn loading [message #49332] Mon, 17 April 2006 12:57 Go to next message
kartsmart is currently offline  kartsmart
I have recently purched a pair of otis 140hz horns , these horns have a mouth dia. of 32" round, TL of 17" and a 7" thorat dia . I was looking for sugestions for a good 10" driver to suit this horn.
Re: 10" horn loading [message #49335 is a reply to message #49332] Mon, 17 April 2006 13:42 Go to previous messageGo to next message
Re: 10" horn loading [message #49363 is a reply to message #49335] Mon, 24 April 2006 17:04 Go to previous messageGo to next message
wayne the back chamber of the horn is to be sized so the driver will resensate at the horn cut off , is this correct ? say if its a 140 hz horn the driver should resenate at 140 hz Bill
Re: 10" horn loading [message #49364 is a reply to message #49363] Mon, 24 April 2006 18:13 Go to previous message
You can do that; It's called reactance anulling and is common practice on basshorns. But I didn't design the π midhorn that way - It's designed to have an open back. The π midhorn actually works well with any rear chamber larger than 0.5ft3. In practice, I don't like the rear chamber to be open because I don't want the rear wave to be presented to the room and interact in any way, so I like using the unused space in the midhorn cabinet as a rear chamber and filling it with absorbent material.
Previous Topic: Tell us about YOUR insecurities
Next Topic: Compensation circuit for 16-Ohm JBL 2426/2370
Current Time: Sun Oct 25 03:20:25 CDT 2026
