Home » Sponsored » Pi Speakers » driver ?
driver ? [message #49320] Fri, 14 April 2006 16:44 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . do you have a Pi alignament to this driver fs =41 hz , Re =6.3 , Qes = 0.64 , Qms = 6.65 , Qts = 0.58 , Vas = 186 lts , Xmax = 4.8 mm , Xmech = 33.o2 mm . this driver is the Delta 15 LF by Eminence . I would like a box as the Stage 4 size . Could fit a stage 4 . Thanks
Re: driver ? [message #49323 is a reply to message #49320] Sat, 15 April 2006 09:37 Go to previous messageGo to next message
The Eminence Delta 15LF is suitable for 3.0ft3 to 20.0ft3 cabinets tuned to 25Hz. PiAlign suggests 4.0ft3, which makes a great alignment for good bass response in a small package. For a subwoofer, go larger than 10.0ft3 if possible.
thanks Wayne * [message #49326 is a reply to message #49323] Sun, 16 April 2006 15:16 Go to previous messageGo to next message
Hy . Thanks for you recomended 4 f3 to the Delta 15 LF. just a last thing that dimensions of port to this box .thanks again
Re: thanks Wayne * [message #49329 is a reply to message #49326] Mon, 17 April 2006 10:45 Go to previous message
The PiAligned cabinet of 4ft3 uses a 3" diameter port, 5" long. Larger boxes will require different ports.
Previous Topic: piezo n pieces
Next Topic: Oh MY
Current Time: Sun Oct 25 03:20:56 CDT 2026
