Home » Sponsored » Pi Speakers » Fun with capacitors
Fun with capacitors [message #49264] Tue, 04 April 2006 19:56 Go to next message
In the 22uF position on the 4Pi crossover the 10uF motor runs with an 8.2 Solen and a 3.3 Clarity yielded a rose-colored mid range. Nicer treble and imaging, tho'
Switched to 16uF and 6uF Solens by-passed with a .33uF Auricap. Roses went away but the harsh treble is back.
Question: what would the 10uF oil caps at the 8uF position do to the crossover?.
Tempted by North Creeks and Mundorfs, too.
Re: Fun with capacitors [message #49265 is a reply to message #49264] Tue, 04 April 2006 20:03 Go to previous messageGo to next message
I just ordered some North Creek 10's to play with- I got 6 of them and plan to try them in the 10 & doubled in the 20 slot. I'll give them awhile to break in and then try the next step.... They're on sale for $6.50 so it's a good deal.
Re: Fun with capacitors [message #49266 is a reply to message #49264] Wed, 05 April 2006 10:36 Go to previous messageGo to next message
You can substitute a 10uF capacitor for C2. I'd prefer 8uF, but 10uF isn't too far off. It will shift the shape and position of the low frequency corner, but only very slightly.
Re: Ixnay on the 10pacitor. 'K? [message #49267 is a reply to message #49266] Wed, 05 April 2006 15:41 Go to previous messageGo to next message
Yeah, there's a shelf there somewhere. Unpleasant tinny-ness combined with that same soupy/syrupy mid-range the oil cap had as a part of the 22uF.
Gonna put back the 8 but a Solen instead of the S-Y-Z.
Re: Fun with capacitors [message #49274 is a reply to message #49264] Thu, 06 April 2006 17:52 Go to previous messageGo to next message
dB is currently offline  dB
Hi Bill,
I find your experience with motor runs interesting and just want to had this paper on special audio electrolytics. I have been reading goods and bads about it.
Best Regards
Re: Fun with capacitors [message #49275 is a reply to message #49274] Thu, 06 April 2006 17:58 Go to previous messageGo to next message
Sorry, I just ADDED the paper website.
Re: Update [message #49276 is a reply to message #49265] Thu, 06 April 2006 19:01 Go to previous messageGo to next message
Got the North Creek Zens this afternoon- very quick service- and immediately installed a 10uF Zen in place of the mylar 10uF stock. I had forgot that one was a basic mylar. I've already got the fix I was looking for- everything else will be gravy from here on out..... Sounds very good, even only a few discs break-in time. Much more open mids, cleaner, sound, and the "congestion" that I heard on some classical music is gone. I'll give this some time, and move on to the others and experiment a little with them too.
Re: Fun with capacitors [message #49277 is a reply to message #49275] Thu, 06 April 2006 19:29 Go to previous messageGo to next message
I'm not sure if this is saying the Jensen lectro-lytics are acceptable or superior in cross-overs?
Re: Fun with capacitors [message #49280 is a reply to message #49277] Fri, 07 April 2006 02:30 Go to previous messageGo to next message
I don't know what best "C/V ratio" stand's for. I think at least they don't explode.
Also, bet that they may be expensive (from catalogue) or difficult to find for doubles of used motor runs. Some tolerances of 10% might be to much, unless you go 5% or less. I agree with you that the final test is the one you do, a work of art if it sounds good.
Another link:
Re: Fun with capacitors [message #49286 is a reply to message #49264] Fri, 07 April 2006 13:07 Go to previous messageGo to previous message
"Switched to 16uF and 6uF Solens by-passed with a .33uF Auricap. Roses went away but the harsh treble is back."
Exactly my experience, IMO - if you want that "sweet & rosy" side of the neutral sound (ha), then Mundorf Supreme is the answer...but we are then in $100 territory for 22µF cap...
Previous Topic: 18" driver for T18 of WBIN cabinet
Next Topic: 2pi bass
Current Time: Sun Oct 25 01:58:22 CDT 2026
