Home » Sponsored » Pi Speakers » speaker recommendation
speaker recommendation [message #49255] Mon, 03 April 2006 19:29 Go to next message
vperalta is currently offline  vperalta
Good evening folks,
I have a quick question, can anyone recommend which speaker kit equivalent to the klipsh la scala. Equivalent or similar to the sound quality and efficiency of the la scala. I'm going to be using the speakers in my shared loftspace. We are planning to do some private parties similar to www.loftnyc.com =)
Thanks for your time and recommendations.
v
Re: speaker recommendation [message #49256 is a reply to message #49255] Mon, 03 April 2006 19:55 Go to previous message
Well; you're in the right place. Pi's Theater/Stage/Pro they all will do exactly what you describe with good sound and they are pretty indestructable. They should have a more refined sound than Lascala's while being as efficient. They use better quality drivers and crossovers.
Previous Topic: JBL 2426/2370 cd compensation and crossover point
Next Topic: Midhorn + Deltalite-II
Current Time: Sun Oct 25 01:57:39 CDT 2026
