Home » Sponsored » Pi Speakers » 90 deg vs. 60 deg horns
90 deg vs. 60 deg horns [message #49192] Mon, 27 March 2006 11:40 Go to next message
Someone over on the HE forum mentioned that in a small listening room his experience was to prefer a more directional horn for high frequencies and gained more image depth and quality. What are your experiences/ comments. Are there any 60 deg horns that I might experiment with in my Theater 4s replacing the Emminence H290 (I think that's the #).
Thanks!
Garland
Re: 90 deg vs. 60 deg horns [message #49194 is a reply to message #49192] Mon, 27 March 2006 13:11 Go to previous messageGo to next message
I don't care much for horns with that tight pattern when used for home hifi. If you want to try it, you can use the LT250. I'd suggest you might want to shift the crossover a bit higher when using that horn. Then again, 1.6kHz isn't too bad - it's a tad on the high side for a 90x40 horn and a little on the low side for a 60x40 horn. So it will probably work pretty well for both horns, probably suitable for either.
The midwoofer in the Theater four π is 15" diameter and has radiating surface area of 132in2 or about 11.5" diameter. At 45º off-axis, it will be about -6dB around 1200Hz. By 2400Hz, the midwoofer's pattern will have narrowed so that it is -6dB at 22.5º or so. Directivity isn't a black-and-white thing, but you still prefer the woofer and tweeter DI to be close through the crossover region.
To expound a little further, if you crossover a direct radiator to a 90º round horn, directivity is matched when wavelength is approximately equal to the diameter of the radiator. In terms of DI, a direct radiator has DI of 10 when diameter equals wavelength and DI of 16 when diameter equals two wavelengths. A 90x40 horn has DI of 11 and a 60x40 horn has DI of 12.5. That makes DI matching of a direct radiator to a 90x40 horn occur a little above 1 wavelength and a 60x40 horn about 1.5 wavelengths.
A 10" driver typically has a radiating surface about 7.5" diameter, 12" driver has about 9" diameter radiator and 15" driver has about 12" radiating diameter. So the frequency where wavelength equals diameter is 1765Hz for a 10" driver, 1500Hz for a 12" driver and 1130Hz for a 15" driver. That makes a 90x40 horn matched to a 10" driver between 2.0kHz and 2.4kHz, a 12" driver between 1.8kHz and 2.1kHz and a 15" driver between 1.3kHz and 1.6kHz. A 60x40 horn is matched to a 10" driver at 2.4kHz to 2.8kHz, a 12" driver at 2.1kHz to 2.4kHz and a 15" driver at 1.6kHz to 1.8kHz.
Re: 90 deg vs. 60 deg horns [message #49204 is a reply to message #49194] Tue, 28 March 2006 10:23 Go to previous message
Thanks, Wayne, for the thorough reply!
G.
Previous Topic: mid-horn
Next Topic: Wayne, impedance compensation calculation?
Current Time: Sun Oct 25 01:59:11 CDT 2026
