Home » Sponsored » Pi Speakers » Parts Express 3.0 cu ft subwoofer cabinet
Parts Express 3.0 cu ft subwoofer cabinet [message #49181] Sun, 26 March 2006 13:40 Go to next message
ccvogel is currently offline  ccvogel
Wayne,
I am planning to make my Four-Pi modular by putting the 2226 woofer in a 3.0 cu ft Parts Express subwoofer cabinet. If I put 4 x 1.375-in ports in the corners of the front face, WinISD says each port should be 2.91-in long for 40 Hz tuning. Does this square with what you would calculate?
Craig Vogel
Re: Parts Express 3.0 cu ft subwoofer cabinet [message #49186 is a reply to message #49181] Mon, 27 March 2006 09:44 Go to previous messageGo to next message
The vent area sounds about right, but I think each port should be longer, around 8" - 10". The Pro four π is about the same size, only slightly smaller, and has a single larger port of approximately the same area as the four you're considering. The four π cabinet works very well, and its port is 10" long.
Re: Parts Express 3.0 cu ft subwoofer cabinet [message #49189 is a reply to message #49186] Mon, 27 March 2006 10:49 Go to previous message
Thanks, Wayne
It's always bothered me that WinISD gives shorter lengths for multiple ports with a cumulative area equal to a single port. Your answer makes a lot more sense.
ccvogel
Previous Topic: would a pi 4 stage or professional be too big for my room?
Next Topic: Compensation circuit when using active crossover
Current Time: Sun Oct 25 01:59:27 CDT 2026
