Home » Sponsored » Pi Speakers » Port Dimension Limitation?
Port Dimension Limitation? [message #49172] Fri, 24 March 2006 14:04 Go to next message
What are the limitations of resizing a port's dimension? For example, if a port's mouth area is a circle of 5 sqr in, can I change it to a rectangular slot of 10 x 1/2? What about 20 x 1/4?
Re: Port Dimension Limitation? [message #49173 is a reply to message #49172] Fri, 24 March 2006 14:41 Go to previous message
For the most part, it's area that you're concerned with. But as the port becomes more asymmetrical, it begins to act differently. There are standing wave issues that can creep in if a dimension is very long compared to the others, and turbulence instead of laminar flow in the port can alter the resistance, which changes its behavior.
Previous Topic: Four-Pi plans and cabinet builder
Next Topic: FS: A few parts 6 CTS KSN-1056 and Eminence Horn
Current Time: Sun Oct 25 01:58:11 CDT 2026
