Home » Sponsored » Pi Speakers » Fountek Ribbon Tweeter
Fountek Ribbon Tweeter [message #48960] Thu, 23 February 2006 13:06 Go to next message
dB is currently offline  dB
Hi,
I need to model a FOUNTEK NeoCd2.0 Ribbon Tweeter in Spice.
Are the parameters I am using ok?
R=6.5Ohms (for Re)
L=0.1mH (for Le)
(1)The problem is that they don't publish the Le parameter.
(2)Also the impedance is 7 Ohms (nominal) but in the graphics curve of response & impedance it shows impedance coming down to 6.75 Ohms @2kHz and 6.5Ohms @3kHz. Which impedance is the best choice to model in Spice, with x-over at 2kHz?
(3)What is this ---> DCR 0.02 ohm, from the factory .pdf catalog?
(4)I am not using compensation for HF, what do you think?
Website here(http://www.fountek.net/products_neo_20.htm);
or here(http://www.madisound.com/neocd2.0.html).
Thanks Wayne.
Best Regards
Re: Fountek Ribbon Tweeter [message #48961 is a reply to message #48960] Thu, 23 February 2006 14:06 Go to previous messageGo to next message
I haven't used the Fountek tweeter, so take these comments with a grain of salt. But based on what you've said, I think your proposed Spice values will describe the tweeter pretty well, particularly if you crossover well above mechanical resonance. A conservatively high crossover point is generally a pretty good idea with a ribbon tweeter. And I don't think you'll want compensation for a ribbon tweeter, because that's really EQ for horns to correct their falling power response.
Re: Fountek Ribbon Tweeter [message #48965 is a reply to message #48961] Fri, 24 February 2006 07:38 Go to previous message
Hi,
Do you know they have a pretty nice transformer in the back, the Founteks. Isn't it like the 50's speakers that had transformers!? I am reading Klipsch Patents right now, #2612558, #4138594 and #4237340 about x-overs networks and horn loading formulas and design.
I helped this other guy in another Forum that needed x-overs for his Founteks and 'modeled it with one second order LF/HF x-over that worked pretty well. The guys in the Forum were amazed because they had plenty of notchs and 4.order LF x-overs that we needed because the 6" midd-bass was peaking at 5/6KHz next to x-over frequency. The result was that going down in the x-over freq. to 2kHz helped, what gave it a beautiful curve down in the problematic area of the peaks in the 5K range. So, the guys were amazed because the second order x-over was giving them a third order slope and that was what everybody was looking after.
I think you 'stated' in your White Papers that it is the voice coil (inductance) 'working'.
Best Regards
Previous Topic: deltalf
Next Topic: Re: Seven pi-18 photos?
Current Time: Sun Oct 25 01:57:31 CDT 2026
