Home » Sponsored » Pi Speakers » K or Pi horn ?
K or Pi horn ? [message #48335] Thu, 01 December 2005 14:14 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne..you said a few threads that you favorite speaker is the 7Pi . So that I only have as reference of a horn speaker the Klipshorn could tell me Wayne if building a 7 Pi is a better way to audionirvana that the Khorns.?
Re: K or Pi horn ? [message #48336 is a reply to message #48335] Thu, 01 December 2005 14:17 Go to previous messageGo to next message
I think so, yes.
Re: K or Pi horn ? [message #48337 is a reply to message #48335] Thu, 01 December 2005 15:16 Go to previous messageGo to next message
GrantMarshall is currently offline  GrantMarshall
Both are great options and both impressive. I got interested in horns when I heard Khorns and have a set of Pi 7's now.
If you like the characteristics of the Khorn sound (almost physical feeling while listening to sound, clear and effortless) you will like the Pi 7's as well.
There are many options that do this and you get to see them at get togethers like the Mid West Audio Fest. (might be a shameless plug for the April 2006 get together )
Grant.
Re: K or Pi horn ? [message #48338 is a reply to message #48336] Thu, 01 December 2005 19:01 Go to previous messageGo to next message
thanks both Wayne and Grant for your answer. A last question Wayne. Could the 7Pi use a 3 way electronic crossover as the marchand XM 9 . thanks
Re: K or Pi horn ? [message #48340 is a reply to message #48335] Thu, 01 December 2005 21:10 Go to previous messageGo to next message
If you spring for the all JBL Pro Theater 7's, and have good amps, then it's no contest. Pi 7 is better. More neutral sound, even more dynamic. My house just doesn't have corners for them, sigh...
Re: K or Pi horn ? [message #48341 is a reply to message #48338] Fri, 02 December 2005 08:38 Go to previous message
You can use an electronic crossover but you'll want to do your homework and set it up properly with respect to summing, slopes, crossover points, etc. If it's set up properly, it will be an improvement. If not, it won't.
Previous Topic: Eminence Gamma-15
Next Topic: Help choose from Pi models
Current Time: Sun Oct 25 02:59:56 CDT 2026
