Home » Sponsored » Pi Speakers » Thermonic 3Pi Plans
Thermonic 3Pi Plans [message #48292] Wed, 23 November 2005 14:44 Go to next message
Derek is currently offline  Derek
Hello,
I am torn between the 2 Pi Towers and possibly the Theater 3 Pi for use with a 300b single ended amp ... but perhaps I should include the Thermonic 3 Pi into the equation also!
So would you be so kind as to send me the plans for the Thermonic 3 Pi please.
Of the three, which in your opinion is the better choice for a 300b ( or possibly 2A3) amplifier in a small room and listened to at a distance of approx 8ft.
Are the horns prone to beaming at such close quarters, or do they require more space around them.
Many thnaks in advance Wayne,
Regards
derek
Re: Thermonic 3Pi Plans [message #48295 is a reply to message #48292] Wed, 23 November 2005 15:15 Go to previous messageGo to next message
I like all three. If you were running a solid state amp, I could nail this down a bit more but with tube amps, there is more difference between amps. So the best thing to do would be to hear all three and decide for yourself.
With a pretty constant voltage source, I'd probably take the Theater three π speaker for most larger rooms and the two π tower for smaller rooms. That's mainly because the Theater three π speaker is more capable of high SPL. But running a tube amp, that isn't a consideration, whereas the impedance curve might be. The tower two π has less impedance fluctuation, and it really sounds good.
The Thermionic three π has its advantages too. It has a pretty benign impedance curve, which makes it tend to sound good on low power SET amps that might have trouble pushing the bass on other speakers. It also has a slightly underdamped alignment, which makes it provide useful bass response even when power levels are low and/or no boundary reinforcement is possible. This is a good speaker for use with amps like the Zen or in open spaces out away from walls and other boundaries.
Please tell me your E-Mail address and I'll send you the plans.
Thanks and my mail address is..... [message #48297 is a reply to message #48295] Wed, 23 November 2005 18:23 Go to previous messageGo to next message
Wanye,
many thanks for the comprehensive reply. yes, please if you could send me the plans I would be greatfull. ... my email address is as above - sorry I forgot it the last time!!
once again - thanks
Derek
On the topic of impedance ... [message #48298 is a reply to message #48295] Wed, 23 November 2005 21:15 Go to previous messageGo to next message
jimbop is currently offline  jimbop
I recently asked about the impedance characteristics of the various 4 Pi speakers, and their suitability for my 2A3 SET amps, but you did not respond. Could you provide some input regarding impedance of the 4 Pi's?
Thanks,
Jim D
Re: On the topic of impedance ... [message #48301 is a reply to message #48298] Thu, 24 November 2005 09:36 Go to previous messageGo to next message
Sorry, I can't imagine that I would have overlooked a question about impedance, but I've been very busy and maybe I forgot. There have been several discussions about this in the past, so the archives are rich with information about it. But in a nutshell, the Theater four π has the flattest impedance curve, followed by the Professional Series four π and then the Stage four π. As for the amp, it depends a lot on the output circuit, not just the tube. Some 2A3 amps will drive any model of π Speaker without problems, others are more sensitive to the load.
You've got mail! [message #48302 is a reply to message #48297] Thu, 24 November 2005 09:37 Go to previous message
Previous Topic: Great Plains Audio Club meeting pics - November 19, 2005
Next Topic: Thermonic 3Pi Plans please
Current Time: Sun Oct 25 02:59:54 CDT 2026
