Home » Sponsored » Pi Speakers » Request for midhorn plans
Request for midhorn plans [message #48114] Tue, 01 November 2005 15:59 Go to next message
RickK.T. is currently offline  RickK.T.
Hello,
I was thinking of buying your midhorn kit, but would like to see plans first.
I saw your post on the midhorn with dims, but it does not show the miter cut angles for the front and throat of horn.
Thanks.
You've got mail! [message #48115 is a reply to message #48114] Tue, 01 November 2005 16:12 Go to previous messageGo to next message
I've sent plans for seven π cornerhorns, which include the drawings for the midhorn. There's also a lot of extra information here in the forum archives, so be sure and look around.
Re: Thanks! n.t. [message #48116 is a reply to message #48115] Tue, 01 November 2005 16:33 Go to previous messageGo to next message
Re: Request for midhorn plans [message #48118 is a reply to message #48114] Wed, 02 November 2005 06:24 Go to previous messageGo to next message
Rajeev is currently offline  Rajeev
Please send me the midhorn plans too !!!
I would also like to have list of cab designs availible with you
Thanks
Rajeev
You've got mail! [message #48119 is a reply to message #48118] Wed, 02 November 2005 06:51 Go to previous messageGo to next message
You can see the rest of the line at PiSpeakers.com.
Re: Request for midhorn plans [message #48132 is a reply to message #48118] Tue, 08 November 2005 09:52 Go to previous messageGo to next message
Thanks Wayne,
I finally got the plans , I have downloaded only the mid horn , is the tweeter horn also a project to be made out of plywood or is it a readymade horn?
What is the despertion angle and driver size for the mid horn?
Rajeev
Re: Request for midhorn plans [message #48133 is a reply to message #48132] Tue, 08 November 2005 11:20 Go to previous message
The midhorn and tweeter used in seven π cornerhorns are 90x40 horns. These match the horizontal radiation angle of the bass, which is set by the wall angle from the corners of the room. Kits come with an ABS tweeter horn flare, but we also have wood horns available. The midrange driver is an Eminence Delta 10 or JBL 2012, depending on the model.
Previous Topic: High pass can be twice the Fs. T or F?
Next Topic: cables and interconnects for Two towers
Current Time: Sun Oct 25 02:59:46 CDT 2026
