Home » Sponsored » Pi Speakers » pi7 midhorn reflections.
pi7 midhorn reflections. [message #47967] Thu, 13 October 2005 00:09 Go to next message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
I have thought about how the throatplate of the midhorn might reflect some midrange back too the speakercone.
How about gluing some felt to the throatplate just in front of the cone ?
Re: pi7 midhorn reflections. [message #47968 is a reply to message #47967] Thu, 13 October 2005 00:36 Go to previous messageGo to next message
Absorbent material doesn't do much unless it's thick. Small wavelengths are out of the passband, so I don't think reflections at those frequencies are harmful because they are highly attenuated.
Horn suggestion. [message #47975 is a reply to message #47968] Thu, 13 October 2005 23:18 Go to previous messageGo to next message
Ahh....
My fault, I was thinking fullrange again
This is only used as a midrange horn, so your right, it doesn´t matter.
A while back you said the Peavey CH-3 horn was one of your favorites.
Do you think this horn is better sounding than the H-290 ?
I found a horn that looks very much like the CH-3.
It´s a Monacor MRH-120.
http://www.paso.co.uk/store/en/view_product/2/555/?product_view=more_info
http://www.bmm-electronics.nl/Product.asp?Product_ID=2618
I ask because the company where I got the PSD-2002 sent me the screw on type, instead of the bolt on type, and it would be easier to use them on these horns, and then ordering some new for the H-290 I have now.
Regards
Kim
Re: Horn suggestion. [message #47977 is a reply to message #47975] Fri, 14 October 2005 03:11 Go to previous messageGo to next message
Wayne.
What´s your opinion on the Peavey 22T vs. the Eminence PSD2002S ?
Re: Horn suggestion. [message #47981 is a reply to message #47977] Fri, 14 October 2005 06:44 Go to previous messageGo to next message
I never tried a 22T because they always sounded artificial to me. In all fairness, the ones I heard were in existing systems, so it may have been something other than the driver.
Re: Horn suggestion. [message #47982 is a reply to message #47981] Fri, 14 October 2005 10:32 Go to previous messageGo to next message
Did you look at the horns in my other post ?
Regards
Kim
Re: Horn suggestion. [message #47983 is a reply to message #47982] Fri, 14 October 2005 18:27 Go to previous message
I really like the Peavey CH-3. It measures well and sounds good too. I don't like the look of the seam, but it doesn't affect performance. Use them with your PSD2002's, they will work very well for you. The H290 sounds nice above 1.6kHz, but it isn't as good as the CH-3 below that. The H290 is a smaller horn designed to be used above 1kHz. In my designs, it's a non-issue because the tweeter is used above 1.6kHz. But the CH-3 is definitely a good choice that will work well for you.
Previous Topic: ** Pi chart request **
Next Topic: Question About MDF and Humidity...
Current Time: Sun Oct 25 03:20:57 CDT 2026
