Home » Sponsored » Pi Speakers » Would your midrange horn work with a PD107 ?
Would your midrange horn work with a PD107 ? [message #47361] Fri, 22 July 2005 12:15 Go to next message
Rob*w* is currently offline  Rob*w*
Hi Wayne,
I chose the precision devices PD107 as a cheaper alternative to the jbl2012 driver for my 3-way project. (I didn't need response below 300Hz either) I'd like to try a horn in the mids to see/hear what it does. Would my driver work ok in it ?
its here btw:
http://www.precision-devices.com/ShowDetails.asp?id=13
Cheers!
Rob
Re: Would your midrange horn work with a PD107 ? [message #47363 is a reply to message #47361] Fri, 22 July 2005 12:22 Go to previous messageGo to next message
I haven't tested the driver, but most of the differences between drivers on this horn are above 1kHz. So that's what you'll want to look at, in regards to crossover for your tweeter.
Re: Would your midrange horn work with a PD107 ? [message #47365 is a reply to message #47363] Fri, 22 July 2005 13:17 Go to previous message
Hi Wayne,
Not a prob as I xo to a 90x40 horn at ~1300 anyway, and use digital crossovers.. I'll build one and give it a listen..
Thanks for the quick reply ,
Rob
Previous Topic: Pi Theatre 4 Speakers
Next Topic: Three Pi Pro
Current Time: Sun Oct 25 03:57:56 CDT 2026
