Home » Sponsored » Pi Speakers » Replacment speaker help
Replacment speaker help [message #47233] Thu, 30 June 2005 20:15 Go to next message
Monomer is currently offline  Monomer
Thsi isnt exactly on topic, but it is sutable for this fourm (I'm ording the speakers from Wayne, after all)
What would be the Best replacment speaker for: http://www.sonicspeaker.com/djx183.htm
whats the best emerance replacment?
Re: Replacment speaker help [message #47235 is a reply to message #47233] Thu, 30 June 2005 21:19 Go to previous messageGo to next message
I'd go with the Stage, Audiophile or Pro Series seven π-18. If you want, you can make the bass bin as a stand-alone reflex cabinet like the four π-18.
Re: Replacment speaker help [message #47243 is a reply to message #47235] Fri, 01 July 2005 14:52 Go to previous messageGo to next message
I was just looking for a replacment LF driver (18inch) for the
they dont list the t/s, box volume or any of that good stuff on their site.
Re: Replacment speaker help [message #47244 is a reply to message #47243] Fri, 01 July 2005 15:42 Go to previous messageGo to next message
You'll need to know more information to do a good swap. Do you know box size and tuning?
Re: Replacment speaker help [message #47245 is a reply to message #47244] Fri, 01 July 2005 16:46 Go to previous messageGo to next message
no idea...
not even any crossover points are given
Re: Replacment speaker help [message #47246 is a reply to message #47245] Fri, 01 July 2005 17:13 Go to previous messageGo to next message
Maybe measure the box and the port? Open it up and check for items inside that will displace internal volume too. You'll want to offset the displaced volume for any internal components, like for the woofer, midrange, tweeter and crossover. You can measure box dimensions and calculate volume, then knowing port size you'll know what the Helmholtz frequency is. Check those things and write back here.
Re: Replacment speaker help [message #47247 is a reply to message #47246] Fri, 01 July 2005 19:13 Go to previous messageGo to next message
will do
maybe a call to Sonic will help? Is it possible to "Milk" info from manufacturers?
Re: Replacment speaker help [message #47248 is a reply to message #47247] Fri, 01 July 2005 22:51 Go to previous message
They might tell you. But it's easy enough to check if they don't.
Previous Topic: 4pi professional
Next Topic: Pi to 83,431 Places
Current Time: Sun Oct 25 04:00:26 CDT 2026
