Home » Sponsored » Pi Speakers » 2206
2206 [message #47162] Wed, 22 June 2005 01:03 Go to next message
andreaspaulsen is currently offline  andreaspaulsen
Hi All
My pro fours are still in the shop and I am not sure they will have access to the livingroom (SWMO's opinion). So I am searching for other options. I am able to put a largeish sub (such as Bills T36S) under the (to be homebuild) couch. I have got a pair of 2206. They pialign in 0.73 ft^3 which really is a very small enclosure. Assuming cornerplacement hanging from the ceiling with the tweeter below the woofer, how low can I cross to the sub, hopefully around 60-70 Hz) ?
Wayne Do you still have the Pro 3 plans using the 2206's. If so, I would like a set.
Cheers and take care with the tablesaw.
Andreas
You've got mail! [message #47163 is a reply to message #47162] Wed, 22 June 2005 03:16 Go to previous messageGo to next message
The Pro three π now uses a DX25 tweeter. I just finished testing about a month ago, and it's a very good loudspeaker. I suggest pairing it with a JBL 2245 in a 10.0ft3 box tuned to 30Hz for a sub. Another option is a JBL 2235 in the same size cabinet, but tuned to 23Hz.
Re: You've got mail! [message #47166 is a reply to message #47163] Wed, 22 June 2005 05:15 Go to previous messageGo to next message
Thanks Wayne
I haven't recieved the plans yet -- problems with your mailserver ??
I did recieve the notification from audioroundtable.com
Cheers
Andreas
Re: You've got mail! [message #47167 is a reply to message #47166] Wed, 22 June 2005 05:43 Go to previous messageGo to next message
No problems, I was just slow to send. The ink on these plans is still wet. I was commissioned to design them for a home theater install recently, and I have just finished finalizing the details.
Re: 2206 [message #47181 is a reply to message #47162] Thu, 23 June 2005 15:26 Go to previous messageGo to next message
LAL is currently offline  LAL
Wayne,
Picking up on Andreas' question, approximately where is the -3db down point on the Pro 3? Any reason why you couldn't use the JBL compression tweeter and Eminence horn on top of the cabinet since I understand that interior room is limited in the Pro 3 cabinet? If so would the Pro 3 use the same crossover as the Pro 4? I am guessing that there may be many interested in a top of the line all JBL system in a size a little smaller than the Pro 4s to use with a subwoofer crossed over around 60-80HZ.
Larry
Re: 2206 [message #47182 is a reply to message #47181] Thu, 23 June 2005 15:52 Go to previous message
The Professional Series three π loudspeaker has f3 of 60Hz. The last version used a compression driver and horn, so you could make that version just like you've described.
Previous Topic: Wayne can you email plans for the 3 pi theater
Next Topic: HF Compression driver without horn flare?
Current Time: Sun Oct 25 03:58:41 CDT 2026
