Home » Sponsored » Pi Speakers » 2 pi/7 pi Hybrid
2 pi/7 pi Hybrid [message #46853] Mon, 09 May 2005 14:37 Go to next message
Ok, so now I'm thinking that I might want to do some sort of hybrid setup using a 2 pi that sits on top of the base horn of the 7 pi. I saw the photos from the Tulsa show and the mid-horn is a bit too imposing. I seriously doubt I can slide it past the wife. Also, I wanted to incorporate adjustable directivity of the mid-range and high freq portions of the spectrum.
So, my question: Can the 2 pi and 7 pi bass unit be seemlessly combined? If not, what modifications (other than crossover, thats the obvious change) need to be done to make for a good transition through the overlapping regions of the audible spectrum.
Since the setup will be located directly in the corner, I was thinking that I'd want the 2 pi to roll off the bass a bit sooner than normal. Also, is there a different driver for the 2 pi that may be a better match to the Stage cornerhorn. Would the Delta 10 work in place of the Alpha 10? If not, what would be the best match for the Omega 15 and DX25 (assuming the Alpha isn't the best match)?
I was going to build the 2 pi portion first and then build the bass units later, too spread out the cost. But, I'd like to build the crossover once, maybe with some build in configurability for pre and post 7 pi.
Re: 2 pi/7 pi Hybrid [message #46858 is a reply to message #46853] Mon, 09 May 2005 16:16 Go to previous messageGo to next message
You can set a two π loudspeaker on top of a seven π bass bin, and crossover at 100Hz - 200Hz. I built several models of seven π cornerhorns over the years, and some used a direct radiating midrange. They sound very nice done that way.
But I think the π midhorn on these looks great. It isn't as imposing as you might think, particularly since the system is in the corner. That always seems to make a speaker much smaller than it really is, because it is out of the way. I think your wife would fall in love with the looks of it if she saw it.
The crossovers are similar, but the current version for the one with the midhorn is the best. Every subsystem is optimized so that it takes full advantage of corner loading, and crossover is seamless at each point, using a minimum of components.
Re: 2 pi/7 pi Hybrid [message #46860 is a reply to message #46858] Mon, 09 May 2005 16:25 Go to previous messageGo to next message
I definitely like the looks myself. What I originally intended to do was increase the width of the front panel to match the width of the midhorn and build the high freq horn such that it is in an enclosure that is also the same width. I was also going to build the midhorn/highhorn so that it can be rotated about 15 degrees left or right. I really like that you can't really see any drivers, so there is no ugly grill needed to hide the drivers.
Re: 2 pi/7 pi Hybrid [message #46861 is a reply to message #46860] Mon, 09 May 2005 16:38 Go to previous messageGo to next message
If you scale up the bass bin of the seven π to make it as wide as the midhorn, you'll have a seven π-18.
Re: 2 pi/7 pi Hybrid [message #46862 is a reply to message #46861] Mon, 09 May 2005 16:49 Go to previous messageGo to next message
Actually, I was going to add triangular "wings" filled with sand. The enclosure volume would remain stock.
Re: 1 pi/7 pi Hybrid [message #46863 is a reply to message #46853] Mon, 09 May 2005 19:41 Go to previous messageGo to next message
If you're going to use a corner horn for the bass, the One PI's might be worth considering. They don't go as low as the 2 PI's, but in this case, they don't have to. They're also smaller too.
Active crossover / bi-amp would be a very good option.
Re: 1 pi/7 pi Hybrid [message #46867 is a reply to message #46863] Tue, 10 May 2005 10:12 Go to previous message
I've actually though about building an active equalizer of sorts to act as a room correction gizmo. Maybe it could be an equalizer/crossover.
I thought the 2 pi would be the right fit since the 2 pi and the 7 pi both had 10" drivers.
Also, I was hoping to create a lower cost solution, that could be bought/build in stages.
Previous Topic: Horn Damping Resistor
Next Topic: JADF'ngQ
Current Time: Sun Oct 25 04:19:08 CDT 2026
