Home » Sponsored » Pi Speakers » Eight PI as extended midrange system
Eight PI as extended midrange system [message #46814] Wed, 04 May 2005 04:58 Go to next message
Eric Mainardi is currently offline  Eric Mainardi
Hello WAYNE,
If I am not wrong, for those like me who want to cover the range 80-2000Hz, the 8 PI seems to be a smart solution since your midhorn works better on the range 200-2000...
If yes, what about using a JBL 2012 within the 8 PI ?
EM
Re: Eight PI as extended midrange system [message #46817 is a reply to message #46814] Wed, 04 May 2005 10:41 Go to previous messageGo to next message
The JBL 2012 does not have the correct electro-mechanical parameters for the eight π, but it sure is nice in the π midhorn. The rear chamber needs to be much smaller for the JBL 2012 if you intend to use it at low frequency.
Is there a solution ? [message #46820 is a reply to message #46817] Thu, 05 May 2005 07:44 Go to previous messageGo to next message
OK Wayne, I see.
My 30Ws work well up to 80Hz, not beyond. So what do you suggest to fill the gap between 80Hz and your Pi midhorn ? Your 8Pi is so attractive...and I think about the high efficiency E-V DL10X but I'm afraid it's too close to the 2012H. Or the TAD TL-1102 ?
Another suggestion [message #46821 is a reply to message #46817] Thu, 05 May 2005 07:56 Go to previous messageGo to next message
The MB-1080C from PAS speakers...
Re: Is there a solution ? [message #46822 is a reply to message #46820] Thu, 05 May 2005 10:07 Go to previous messageGo to next message
I'll bet the EV driver works very well in the π midhorn, certainly worth a try. As for the 30W, I think it could be used to augment the system as a subwoofer instead of being used as the primary woofer. Or you could simply build a larger midhorn to go with it and shift all the crossover points down.
Re: Another suggestion [message #46823 is a reply to message #46821] Thu, 05 May 2005 10:09 Go to previous message
The PAS 1080 will probably work very well in a π midhorn. If you use it, please let us know how it sounds.
Previous Topic: 902's, JJ's and Me
Next Topic: Alpha 15 in 8 cubic foot box
Current Time: Sun Oct 25 04:19:14 CDT 2026
