Home » Sponsored » Pi Speakers » midrange horn gain
midrange horn gain [message #46726] Sun, 17 April 2005 17:31 Go to next message
djstan is currently offline  djstan
Want to try a pair of Audax 8 inch midranges (HT210T0) in a pi-type horn crossed to the Eminence 2002 at 1.6 khz. My question is how much gain would the horn provide? From what I can tell you get about a 10db of gain. The Audax mids are rated at 99db sensitivity and pretty flat according to their charts, so I'm assuming in a mid-horn
I might be looking at 109db. Does this seem reasonable. The Yorkville TX8 uses an 8"Audax mid and I have a feeling it is similar to mine, and they spec the midrange at 109db sensitivity. Wayne, what is the sensivity of your midrange horn. Thanks
Re: midrange horn gain [message #46733 is a reply to message #46726] Sun, 17 April 2005 22:14 Go to previous message
The midhorn provides about 10dB more than direct radiation into freespace. But remember that the range is basically 200Hz to 2kHz. In that range the driver is probably more like 95dB/W/M in freespace. The average sensitivity is sometimes shown higher because it includes output at high frequencies where collapsing DI and cone flex modes increase output. Average the low frequencies and high frequencies together and the SPL is higher. In a 90x40 midhorn, you should probably expect about 105dB/W/M or so.
Previous Topic: Can I get away with stacking capacitors like Legos?
Next Topic: midrange horn gain
Current Time: Sun Oct 25 05:06:14 CDT 2026
