Home » Sponsored » Pi Speakers » Theatre 4 Pi Plans and Questions
Theatre 4 Pi Plans and Questions [message #46626] Thu, 31 March 2005 18:08 Go to next message
J Gregory is currently offline  J Gregory
Wayne,
Great work. I was wondering if you could help me out with a few questions.
First, is it possible to turn a Theatre 4 Pi on its side in order to use it as a center channel without dramatically altering its performance?
Second, is there an alternative configuation where the 4 Pi can be constructed so that instead of being "wide but not deep" it can be "deep but not wide". This would put the woofer on the side instead of the front of the speaker. Is this possible, or would it screw up the whole Pi Alignment method?
Third, could you email plans for the Theatre 4 Pi to me?
Fourth, would the Theatre 4 Pi work in a "in-wall" solution?
Thanks for any replies and I'll send pics when it's all finished.
Kind Regards,
John
You've got mail! [message #46630 is a reply to message #46626] Thu, 31 March 2005 18:51 Go to previous message
John Lapaire made his Theater four π's taller and thinner and several others have as well. To be honest, I never have but I suspect it will sound just fine as long a you keep the physical relationship of the woofer and tweeter the same. Keep them the same distance apart and you'll be OK. I'd also suggest that you might also model the system with Martin King's spreadsheet to make sure standing wave modes don't cause a spike in the midrange.
About laying the Theater four π sideways, that will work just fine but I would suggest that you reposition the tweeter so that its horizontal pattern is maintained. I'd probably move it to be above the woofer when placed in this position too.
Previous Topic: GE 97F motor run caps on tweeters...Yum!
Next Topic: JBL 2118H
Current Time: Sat Nov 14 16:53:03 CST 2026
