Home » Sponsored » Pi Speakers » Cerwin Vega D6 Cabinets
Cerwin Vega D6 Cabinets [message #46030] Sat, 18 December 2004 18:10 Go to next message
steve s. is currently offline  steve s.
Just picked up a pair of these cabinets which are in good condition, but both woofers torn. They use a 12" woofer, 4 1/2" mid and a small horn tweet. Would any of the Pi speaker kits work in these cabinets?
They are 26"Tx17"Wx15"D and 1" thick MDF, ported in the rear. I could cut as needed on the baffle. Would like it to be 95dB+ if possible. Thanks.
Re: Cerwin Vega D6 Cabinets [message #46034 is a reply to message #46030] Sat, 18 December 2004 21:29 Go to previous messageGo to next message
The Delta 12LF might work well in those cabinets, depending on the porting. Might be worth a try. But you might also check into reconing those speakers. It's generally pretty cost effective. Call David Miller at Speakerworks, (918) 664-6299.
Re: Cerwin Vega D6 Cabinets [message #46038 is a reply to message #46034] Sun, 19 December 2004 05:13 Go to previous message
Thanks Wayne, I'll look into that.
Regards, Steve
Previous Topic: Studio 2 pi interior volume
Next Topic: Pi Seven vs Pi Seven-18 Heighth
Current Time: Sat Nov 14 16:41:47 CST 2026
