Home » Sponsored » Pi Speakers » What's The Difference Between A Horn And...
What's The Difference Between A Horn And... [message #45703] Fri, 29 October 2004 16:35 Go to next message
Fresno is currently offline  Fresno
A Bass Reflex?
Fresno
Re: What's The Difference Between A Horn And... [message #45704 is a reply to message #45703] Sat, 30 October 2004 22:48 Go to previous messageGo to next message
A horn is like a megaphone. It is designed to point the sound, and make it louder in a targeted area. A bass reflex speaker is not directional. It's main feature is that it uses a Helmholtz resonator to improve bass response.
Re: What's The Difference Between A Horn And... [message #45706 is a reply to message #45704] Sat, 30 October 2004 09:00 Go to previous messageGo to next message
But what is the structural difference? Based on looking at pictures, it looks like horns have a hard surface (wood or plastic) that vibrates the sound out rather than a paper cone.
If that is correct, is the "thing" that vibrates the wood or paper the same thing?
Fresno
Re: What's The Difference Between A Horn And... [message #45707 is a reply to message #45706] Sat, 30 October 2004 09:25 Go to previous messageGo to next message
The horn and the radiating diaphragm are two separate things. The diaphragm can be made of any material, just like a direct radiating speaker. You'll see paper, plastic, cloth, metal and composites.
Compression horns put more pressure on the radiating diaphragm than it would have without the compression chamber. There is a constriction in area between the diaphragm and the horn throat which causes pressure to be higher than it would be in free air or mounted on a baffle. So for this reason, the radiating membranes on drivers that are designed to be used on horns are often made more rigid than general purpose drivers.
Re: What's The Difference Between A Horn And... [message #45733 is a reply to message #45706] Fri, 05 November 2004 06:26 Go to previous message
Rory B. is currently offline  Rory B.
The horn and the enclosure panels themselves do not vibrate. Instead, the horn shape acts as a waveguide to the sound produced by the driver.
Previous Topic: Studio 2's Finished, check them out.
Next Topic: Pi 8's up and running!
Current Time: Sat Nov 14 16:41:40 CST 2026
