Home » Sponsored » Pi Speakers » Two Pi with off-sized speaker box
Two Pi with off-sized speaker box [message #45673] Sat, 23 October 2004 12:22 Go to next message
BrianG is currently offline  BrianG
Wayne,
I'd like to convert an old pair of speakers to Two Pis. The box size is ~5000 cubic inches - between the regular and tower two pi boxes. Is there a tool to calculate whether there is a valid alignment at that size? Or are the two proper alignments only available at the regular and tower box sizes?
thanks,
Brian
Re: Two Pi with off-sized speaker box [message #45674 is a reply to message #45673] Sat, 23 October 2004 13:00 Go to previous message
Use the formula below to calculate the port size. For the Alpha 10's used in two π's, you'll want to tune the box to 40Hz.
Here's a little BASIC program that will calculate the formulas for you, if you can still find an old BASIC interpreter around somewhere.
    10 INPUT"Enclosure Volume";VE
    20 INPUT"Diameter of Port";PD
    30 INPUT"Length of Port";PL
    40 VB=VE*1728:PI=3.1415926535:AP=PI*((PD/2)^2):LC=PL+((8*PD)/(3*PI))
    50 FR=(13548/(2*PI))*(AP/(VB*LC))^.5
    60 PRINT"Fr =";FR;"Hz."
    70 GOTO 10
5000 cubic inches is 2.9ft3, which is a nice size for the Alpha 10 driver. You could go with a 4" diameter port that's 4" long or a 3" diameter port that's 2" long.
Previous Topic: Stage 3 Omega pro
Next Topic: Kits Plans
Current Time: Sat Nov 14 16:41:19 CST 2026
