| Ever heard of JBL 2122H? [message #45538] |
Sun, 10 October 2004 12:40  |
Russellc
Messages: 397 Registered: May 2009
Illuminati (1st Degree) |
Hello, seller claims these came out of JBL 4344 and 4346 speakers. Can these be used in place of the 2123H with success? Thanks,
| Re: Ever heard of JBL 2122H? [message #45542 is a reply to message #45539] |
Sun, 10 October 2004 22:05   |
GM
Messages: 114 Registered: May 2009
Viscount |
Hmm, what specs are you using? The ones I have are poles apart and no way will they interchange without some serious compromising of midbass/LF performance. GM
| Re: Ever heard of JBL 2122H? [message #45543 is a reply to message #45542] |
Sun, 10 October 2004 22:22   |
Messages: 19105 Registered: January 2001
Fts is much lower than the 2123 and Qts is too. Vas is much higher on the 2122, and it can be used as a midbass or a midwoofer, whereas the 2123 really can't be. But I think Cody was planning to use the driver as a midrange, which will make bass performance less relevant. Here are the specs:2122H Fts=40, Qms=1.9, Qes=0.26, Qts=0.23, Vas=2.3ft3 2123H Fts=85, Qms=2.5, Qes=0.37, Qts=0.32, Vas=0.7ft3
| Re: Ever heard of JBL 2122H? [message #45567 is a reply to message #45545] |
Thu, 14 October 2004 19:37   |
Russellc
Well, I think they will to. It's a fair sized investment for all JBL motors. I have been fortunate enough to stumble on some good bargins on the "older model" JBL drivers; The 2225H intead of 2226H, the 2123H instead of the newer 2013H and the 2425H instead of the 2426H. This saved about 50% over buying the brand new motors which would be nice, but a little beyond the range I wanted to spend. I still need the crossovers, the cabinets and various odds and ends, not to mention the midhorns and some kind of horn flare for the 2425H drivers. Right now they have the plastic flare for the 4 PI studio size, I believe it was model H-290. I was going to use the 2425 H and 2225H in a 4 PI, but when I got a set of the 2123H I decided to go for it with the 7Pi version w/ the mid horn. I need something else for the high frequency flares, would love one of Bill M's .... but I'll have to wait awhile for that. Deferring gratification, Russellc
