Home » Sponsored » Pi Speakers » mid horn for pi 7
mid horn for pi 7 [message #45395] Mon, 20 September 2004 13:06 Go to next message
Zeno is currently offline  Zeno
hi wayne,
if i build the mid horn to go with the pi 7 corner horn do i need to seal the driver (alpha 10)? what will be the ideal volume?
Zeno
Re: mid horn for pi 7 [message #45396 is a reply to message #45395] Mon, 20 September 2004 13:18 Go to previous messageGo to next message
The back volume is to be made larger than 0.5ft3 Above that, it can be arbitrarily large.
Re: mid horn for pi 7 [message #45397 is a reply to message #45396] Mon, 20 September 2004 14:41 Go to previous messageGo to next message
say-say wayne
in chinese mean thanks
zeno gabriel
Re: mid horn for pi 7 [message #45398 is a reply to message #45397] Mon, 20 September 2004 15:07 Go to previous messageGo to next message
Give those seven π's a try! I think you'll love them.
The eight π is a lot of fun too. Less expensive and very versatile. I think they look cool too.
Re: mid horn for pi 7 [message #45400 is a reply to message #45398] Tue, 21 September 2004 03:38 Go to previous messageGo to next message
hi wayne,
i already own the pi 4, that's why i go for the pi 7 all i need is an extra driver but i have got a situation here now, i bought the alpha 10" i never knew the pi 8 and the mid horn are using different driver, is there anyway i can use the alpha 10" for my pi 7, what will be the changes in the cross over, enlighten me
"say-say"
zeno gabriel
Re: mid horn for pi 7 [message #45401 is a reply to message #45400] Tue, 21 September 2004 14:47 Go to previous messageGo to next message
You can use the Alpha 10, just like the eight π loudspeaker uses. But if you are building a seven π loudspeaker, use the crossover for the seven π, so that low frequencies aren't augmented and sent to the Alpha 10. You also don't need to vent the midhorn rear chamber. Just make it like is shown in the seven π plans.
pi 7 plan & crossover [message #45402 is a reply to message #45401] Tue, 21 September 2004 20:25 Go to previous messageGo to next message
hi wayne,
Perhaps you can send me the plan for the pi 7
"say-say"
zeno gabriel
You've got mail! [message #45403 is a reply to message #45402] Tue, 21 September 2004 20:41 Go to previous messageGo to next message
Re: You've got mail! [message #45404 is a reply to message #45403] Tue, 21 September 2004 20:52 Go to previous message
"say-say" wayne,
i got your mail, i am having the theater pi 7.
Zeno gabriel
Previous Topic: Question for PI Corner Horn Owners
Next Topic: Forum Problems
Current Time: Sat Nov 14 16:42:27 CST 2026
