Home » Sponsored » Pi Speakers » Old style loudspeakers
Old style loudspeakers [message #45154] Tue, 03 August 2004 20:30 Go to next message
Mattulator is currently offline  Mattulator
I recently picked up 2 peavey LH-1 enclosures and they are the suspended wedge style with the driver facing the rear wall of the cabinet.
What is this style called and where can I find information on the pros/cons of this design.
Thanks
Re: Old style loudspeakers [message #45157 is a reply to message #45154] Wed, 04 August 2004 11:24 Go to previous messageGo to next message
Are you sure your speakers aren't FH-1's? Do they look sort of like Klipsch LaScala's?
If so, they're a 60Hz midbass horn. Horns generate more output than direct radiators over a narrow frequency range. The FH-1 has sensitivity of about 104dB/W/M and can generate maximum output of 125dB/M from 60Hz to 400Hz or so.
Re: Old style loudspeakers [message #45159 is a reply to message #45154] Wed, 04 August 2004 11:36 Go to previous message
spkrman57
If they are FH-1's, how you orient them will also affect the response. I have turned mine on their sides and found better bottom end, but poorer mids. They truly operate best run from 80hz to around 250hz, above and below that is usually affected by the room and driver used.
Ron
Previous Topic: Pi 8 question
Next Topic: Speaking of Pro Amps
Current Time: Sat Nov 14 16:41:15 CST 2026
