Home » Sponsored » Pi Speakers » Finished my Stage Series 4 Pis!
Finished my Stage Series 4 Pis! [message #45048] Thu, 22 July 2004 20:34 Go to next message
James W. Johnson is currently offline  James W. Johnson
Id say WOW! but that is just too dramatic and old but the truth is that it only took a minute of playing them to figure out that they are like my Klipsch Reference series to the tenth power!! Excuse my language but holy crap!
Gorgeous! [message #45050 is a reply to message #45048] Fri, 23 July 2004 04:10 Go to previous messageGo to next message
Those look stunning, James. They're really gorgeous!
Re: Finished my Stage Series 4 Pis! [message #45051 is a reply to message #45048] Fri, 23 July 2004 13:41 Go to previous messageGo to next message
Very nice James. I'm glad every thing worked out for you and they exceeded your expectations. Time to build a matching center channel! I think a Premium 3PI would be a great match.
What kind of screws did you use to attached the horns to the baffle? Did you insert plugs over the screw to cover them up?
Gar.
Re: Great Looking & V. Nice matching on the veneer. nt [message #45052 is a reply to message #45048] Fri, 23 July 2004 13:43 Go to previous messageGo to next message
Re: Finished my Stage Series 4 Pis! [message #45055 is a reply to message #45051] Sat, 24 July 2004 08:09 Go to previous messageGo to next message
Gar, they are 5/8" drywall screws, they worked out very nicely. I had some #8 stainless screws with some washer ready to go but when I discovered how little space there is between the screw and hole I had to go with something less stressing on the wood. I predrilled and torqued the screws down with the lowest setting on my drill...it worked out nicely. (shame on Eminence BTW!)
Also I got two different looking H290 horns in that one must be a new rev. because its hole could have been much smaller...probably at least an inch smaller both ways.
I think i'll take the stainless screws out of the Omegas and replace them with black screws as well...I am fortunate to have a hardware store nearby with an insane selection of screws and they have some #8 black screws.
Re: thanks but the veneer came in 4'x8' sheets! :-) nt [message #45056 is a reply to message #45052] Sat, 24 July 2004 08:13 Go to previous message
nt
Previous Topic: Driver Is Blown :(
Next Topic: Old JVC'S
Current Time: Sat Nov 14 16:29:30 CST 2026
