Home » Sponsored » Pi Speakers » small wall mounted cornerhorn
small wall mounted cornerhorn [message #44757] Wed, 16 June 2004 19:55 Go to next message
jeff g is currently offline  jeff g
is it doable?
i'm looking to put some small speakers mounted on the wall in the corner - out of the way of little hands that like to poke things.
thanks for any advice
Re: small wall mounted cornerhorn [message #44761 is a reply to message #44757] Thu, 17 June 2004 05:01 Go to previous messageGo to next message
I think it's an excellent idea. What will you use for a back chamber? Or will it be sort of an infinite baffle, with the back chamber being the other side of the wall?
Re: small wall mounted cornerhorn [message #44767 is a reply to message #44757] Thu, 17 June 2004 09:04 Go to previous messageGo to next message
Take a look at these. Not real small, but compared to most of what
everybody else is building...
pseudo 1 Pi corner horns
Chris
Re: small wall mounted cornerhorn [message #44768 is a reply to message #44767] Thu, 17 June 2004 09:18 Go to previous messageGo to next message
Those are really cool looking little speakers. I like 'em!
pi 1 variation? [message #44772 is a reply to message #44761] Thu, 17 June 2004 10:29 Go to previous messageGo to next message
i have no plans, i was just wondering if anyone had done something like this.
i guess i envisioned some variation of the pi one - maybe just a mini version of the pi 7 cornerhorns with pi one components.
disclaimer: i really don't have any technical knowledge regarding speaker design, i just like building stuff
nice! [message #44773 is a reply to message #44767] Thu, 17 June 2004 10:32 Go to previous messageGo to next message
would you have plans, or even a sketch for this design?
Re: nice! [message #44777 is a reply to message #44773] Thu, 17 June 2004 11:20 Go to previous messageGo to next message
I did make drawings just so I could tell how the shapes would
fit. I can take some quick measurements and let you know.
If you want something similar, you'll have to make the wall
hangers too. Not hard, but do need to be pretty sturdy. I had
to lag bolt them into the corner studs.
Chris
Re: small wall mounted cornerhorn [message #44784 is a reply to message #44767] Fri, 18 June 2004 10:41 Go to previous message
hi Jeff,
The fronts are ~16" wide, sides ~10", and across the back 4.5".
Its 9.5" deep. I didn't write down the angle, but draw it out
on graph paper first, calculate the angle, set the saw once and
make all the cuts at the same time. I've never been able to
set the same exact angle twice.
I forgot to measure the hight, but I think its between 16" and 18".
It will be determined by your required volume. I can give you
construction details if you need them. Let me know if you need
anything else.
Chris
Previous Topic: Distortion specs for loudspeakers...
Next Topic: What makes a Pi Speaker?
Current Time: Sat Nov 14 16:29:50 CST 2026
