Home » Sponsored » Pi Speakers » Two pi tower dimensions
Two pi tower dimensions [message #44340] Thu, 08 April 2004 23:54 Go to next message
socalguy is currently offline  socalguy
Hi Wayne,
On your site, it says that the dimensions for Two Pi towers is 46x16x13. Is it alright to go a "touch" bigger?? Is 48x14x15.5 OK? It's less than 0.5 ft3 (outside) I only ask because my friend and I want to build two different kits (won't name the other) to A/B for fun, and it would be MUCH easier to build two pairs of boxes exactly the same size. I realize they wouldn't be stock or "Pi-approved" then, but wasn't sure how much difference it would make. Thanks for your info. Can't wait to make some Towers!
Rich
Re: Two pi tower dimensions [message #44341 is a reply to message #44340] Fri, 09 April 2004 00:05 Go to previous message
Sure, you can make them larger but be careful. Alignments like this are actually pretty sensitive to cabinet size and can get peaky in a hurry. Some alignments are pretty forgiving, but this one pushes the woofer as deep as it can. Those tend to get a bit less forgiving. So try to keep your internal volume the same.
Previous Topic: Subwoofer project Zmax
Next Topic: Integration of mid and sub into theater 4's
Current Time: Sat Nov 14 16:30:52 CST 2026
