Home » Sponsored » Pi Speakers » Compensation Network connection
Compensation Network connection [message #44232] Tue, 23 March 2004 19:53 Go to next message
HaknHendrix is currently offline  HaknHendrix
About to solder the tweeter compensation resistors together, along with the capacitor. I hope this diagram is understanble, but want to make sure I've got it before I commit solfer.
The diagram below should represent 4 pairs of 16 ohm resistors in parallel serial combination.
Top View of Resistor Pack
O----O----O----O
O----O----O----O
Bottom View of Resistor Pack
T1------O----O O----O-----C3
T2------O----O O----O
C1
Thanks
Hakn
Re: Compensation Network connection [message #44233 is a reply to message #44232] Tue, 23 March 2004 20:35 Go to previous messageGo to next message
Not sure if this is what your looking for, but I think it is.
See this post: http://www.audioroundtable.com/PiSpeakers/messages/13262.html
Adrian
Re: Compensation Network connection [message #44262 is a reply to message #44233] Wed, 31 March 2004 07:24 Go to previous messageGo to next message
OK - I'm ready to fire up the soldering iron - well almost.
I sharpened my pencil, diagrammed the compensation network based on the 4 Pi schematics Wayne sent me - lots of lines connecting the resistors (series/parallel), and built a 3 dimensional model out of cardboard. I then looked at the URL sent to me with the attached graphic:
and modeled this out of cardboard - and they are two different beasts.
So, if I duplicate the compensation network based on the picture provided via the URL - I feel like I should be Good to Go. It will be connected to the Eminence PCB.
The woofer compensation network looks easier - connect the dummy resistor to the capacitor, and connect the leads in parallel prior to connecting to the woofer.
Re: Compensation Network connection [message #44268 is a reply to message #44262] Wed, 31 March 2004 17:04 Go to previous message
I have a suggestion. When you build-up your cluster of four resistors to make R1 and another four to make R2, measure them with a DVM to make sure the result is 16 ohms for each one. It's just a series-parallel connection that is physically shaped in a way that's convenient.
Previous Topic: Basshorn plans please - Wayne
Next Topic: help on Beyma 12" midbass driver enclosure
Current Time: Sat Nov 14 16:30:53 CST 2026
