Home » Sponsored » Pi Speakers » Port Flare on 2 Pi
Port Flare on 2 Pi [message #43946] Fri, 13 February 2004 21:20 Go to next message
Caddis is currently offline  Caddis
Wayne,
I would like to flare the port on my 2 Pis, perhaps with a 1/2 or 3/8 inch round over bit on the router. If it matters, I am using 3/4" stock with appropriate compensation to keep the design cabinet volume. How would I change the port length to compensate for the flare? I do not want to change the Helmolzt frequency, but I would like to reduce the noise from a sharp transition at the mouth of the port. Thanks for any help you can provide.
Caddis PM
Re: Port Flare on 2 Pi [message #43949 is a reply to message #43946] Sat, 14 February 2004 04:13 Go to previous message
The Helmholtz forumula makes no provisions for flares of this sort. You may have to come at it from an empirical point of view. I would suggest that if you just radius the edge, you'll probably not alter the Helmholtz frequency very much. But you can always double-check when your done to be sure.
Previous Topic: Audiophile 7 pi plan request and a question
Next Topic: Formula's
Current Time: Sat Nov 14 15:54:04 CST 2026
