Home » Sponsored » Pi Speakers » Question on Theater 3
Question on Theater 3 [message #43937] Fri, 13 February 2004 12:00 Go to next message
Why the use of the Delta12LF, and not the regular Delta12?
Other than the better low end punch, are there any other difference between the Theater 3 and the Thermionic 3? Any difference in the midrange?
thanks
Gar.
Re: Question on Theater 3 [message #43940 is a reply to message #43937] Fri, 13 February 2004 12:15 Go to previous messageGo to next message
I chose the Delta 12LF because it did more of what I wanted done in this particular spot in the model lineup. You get good bass response in a small package when using this woofer, where most of the other Eminence pressed-frame units need huge boxes.
Re: Question on Theater 3 [message #43941 is a reply to message #43940] Fri, 13 February 2004 15:07 Go to previous messageGo to next message
Hi Wayne,
Can you forward a copy of the plan.
thanks,
gar.
You've got mail! [message #43951 is a reply to message #43941] Sat, 14 February 2004 04:39 Go to previous message
Previous Topic: Formula's
Next Topic: midrange JBL conical?
Current Time: Sat Nov 14 15:54:01 CST 2026
