Home » Sponsored » Pi Speakers » request pi seven cornerhorn plans
request pi seven cornerhorn plans [message #43596] Thu, 08 January 2004 11:40 Go to next message
artsybrute is currently offline  artsybrute
Hi Wayne,
I finally have a couple of weeks to start cutting wood. I don't know if drivers or plans have changed over the last year, so I just want to make sure that I have the latest version of the plans.
Please send me plans for Pi Seven Cornerhorns for use with Eminence Delta 15 drivers.
I had problems receiving large files at my hotmail addy last time. If I have problems again, I'll reply to your email with another addy offline. Thanks.
Gorgeous site, Wayne!
forgot to mention: theater series [message #43597 is a reply to message #43596] Thu, 08 January 2004 11:42 Go to previous messageGo to next message
You've got mail! [message #43598 is a reply to message #43597] Thu, 08 January 2004 12:24 Go to previous messageGo to next message
Thanks! some questions... [message #43599 is a reply to message #43598] Thu, 08 January 2004 13:08 Go to previous messageGo to next message
Thanks Wayne. They came through fine.
Question: You show a vent that's 3-1/4" deep and your plans specify 3/4" plywood.
I know it will end up weighing a ton, but I'm using 1" mdf. So
1. Are the vent length and width dimensions inside or outside?
2. Should I shorten up the depth of the vent by 1/4"?
3. Should I move the vent location 1/4" away from the side and bottom?
4. I maintained inside dimensions for the overall width,length and height of the speaker, adding 1/2" to each overall. Is this correct?
Thanks again!
Notes for using thicker wood [message #43601 is a reply to message #43599] Thu, 08 January 2004 14:00 Go to previous messageGo to next message
The port should be 3.25" long from entrance to exit, so if the baffle is 0.75" thick, then make the duct 2.5" long so the total length is 3.25". Likewise, if the baffle is 1" thick, then make the duct 2.25" long. That's if you butt the tube right up to the baffle. If you insert the tube flush with the baffle, then naturally it should be 3.25" long. Whatever you have to do to make the duct 3.25" long overall, entrance to exit, that's what you should do.
Thanks Wayne - you da best (nt) [message #43603 is a reply to message #43601] Thu, 08 January 2004 14:20 Go to previous message
Previous Topic: New address, same format
Next Topic: Final Pix Premium Stage 4 Pi in Theatre 4 Pi
Current Time: Sat Nov 14 15:52:36 CST 2026
