Home » Sponsored » Pi Speakers » Other horn flares
Other horn flares [message #43436] Mon, 22 December 2003 03:23 Go to next message
Has anyone here used the Eminence H295 or H395 horn flares before and have any comments on them?
They are both 90x40deg horns, constant directivity type. The H295 is small physically like the H290 radial and Peavy CH3, the H395 is more like the size of the JBL Bi-Radial 2370. I was thinking that perhaps the CD horn might be better over the radial horn as it should be able to keep tighter pattern control in both vertical and horizontal planes, rather than only in the horizontal plane which the radials do.
However the constant directivity horn by not having a dropping HF response as we move further off axis vertically would create a wider overlap region between itself and the subsystem right below it (eg: woofer) so destructive interferance would be greater between them, which isn't a good thing. With the radials, destructive interferance is less because vertical dispersion is limited, but vertical pattern control is not maintained - big drop in HF output as we move further off axis. What do people here consider the better alternative? Maintained vertical pattern control at expense of more destructive interferance or poor vertical pattern control/big drop in HF output off axis but with less destructive interferance?
Unfortunately Eminence said they have no measurement graphs at all on them as they let manufactures take their own measurements as part of a complete system.
Re: Other horn flares [message #43439 is a reply to message #43436] Mon, 22 December 2003 05:56 Go to previous messageGo to next message
I've used the H295, H395 and LT350. I think George (replay) has used the H395. They all sound reasonably good, and act as you might expect. The LT350 is louder, on-axis, and has narrower dispersion, but only at high frequencies. Vocal frequencies can be heard loudly clear around the corner, far off axis. The H295 and H395 have wider dispersion at higher frequencies, but also need more EQ up there.
Re: Other horn flares [message #43441 is a reply to message #43436] Mon, 22 December 2003 16:05 Go to previous message
Grant Marshall is currently offline  Grant Marshall
Hi Adrian.
I got the Emminence CD flares when I bought the Georges speakers. I have replaced them with some Altec 32B bent horns.
I found the CD flares to have a very small sweet spot and the Altecs add a lot more soundstage (used for music in my living room). From what I've gathered on the Pi and hi efficiency forums the soundstage often comes from reflected sound which I suspect the CD flares cut down on. For some applications you might want to direct sound so whether you want them or not depends on what you want to use your speakers for.
Grant.
Previous Topic: power amp specs
Next Topic: How Much Power?
Current Time: Sat Nov 14 15:53:17 CST 2026
