| same speakers [message #43295] |
Mon, 08 December 2003 10:29  |
canjie
Messages: 9 Registered: May 2009
Esquire |
Hello People Maybe this question sound's stupid too you but I really want to know an answer. Let's say that we are comparing two speakers with the "same" T/S parameters: One has for example this parameters: SPL = 100 dB and Power = 600 W , 15"diameter, etc... same Second one: SPL 100 dB and Power = 200 W , 15"diameter, etc...same So, the only thing different is the Power of the speaker, which is different. What is different between these two speakers besides that first one can handle more power?
| Re: Power handling and compression [message #43305 is a reply to message #43296] |
Tue, 09 December 2003 05:30   |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
Wayne, A couple of questions about power handling: In terms of compression, is the result simply a reduction of volume, or a reduction of dynamic range? For example, is the signal compressed across the entire spectrum of wattage, or does it leave the lower signal alone, but compress the higher (louder) signal? If it's the first, I can probably live with it as it does not "change" the sound, but just a reduction in a linear fashion. However, a reduction of dynamic range will change the way the recording was meant to be heard. Second question: At low volumes, do drivers with higher power handling sound different than those with lower power ratings. For example, if played at a mid volume, how does an Eminence Delta sound compared to an Alpha in terms of tonal characteristics? thanks, gar.
| Re: Power handling and compression [message #43307 is a reply to message #43305] |
Tue, 09 December 2003 06:26   |
Messages: 19105 Registered: January 2001
Compression is greater as power is raised. At very low power levels, compression is zero and it rises to maximum at full output. Some of the better drivers only have 3dB or so compression at full power levels of several hundred watts. This is pretty impressive. But you'll also find drivers that have twice as much compression as this at full output. As for the "sound" of different drivers, my take is that they are a simple enough system that you can understand them reductionistically. System behaviour is the sum of its parts, and while some systemic behaviour arises, the system is simple enough that it is easily described and easily predictable. So when you take the electro-mechanico-acoustic properties and examine them, you can describe the speaker with a fair degree of accuracy. The most difficult part to examine reductionistically is cone flex, and even this can be found deterministically with some amount of success. This is relatively chaotic motion though, and so description of a system in chaotic behavior is best seen as averaged because it jumps around a bit. Anyway, the point of all that is that drivers sound different when their properties are different. The system acts a a set of filters, each having frequencies of interest and bandwidth or Q. So a large part of the speaker's character is determined by these filter properties. This is a big reason why two speakers can sound different when they have different specifications but similar quality of build construction. Another set of properties that are very important are motor-related and determine what kinds of distortion and amounts will be present. When you have two drivers that are tuned similarly, but one is of better build quality, this is where you'll usually notice this. A great example if in prosound woofers - many have similar specs but the $500 woofer probably has a more linear magnetic structure than the $150 woofer, and so 2nd and 3rd order harmonics are greatly reduced. And the third set of properties are in cone construction, which determines how and when the cone will flex. Some are designed to extent upper frequency performance, and this is usually done with controlled resonances in cone flex - Controlled breakup modes. These provide extended smooth response up high, but the response in this mode is not as smooth as it is down low. Other devices are built to reduce cone flex as much as possible, but when the cone "breaks away" and begins to flex, it does so rapidly and violently, so they should not be used in this region at all, and must necessarily be used over a fairly narrow bandwidth. These are pretty simple systems, and so tuning of each property is pretty straightforward. I think that's why it is such a popular field for do-it-yourself builders. Lots of fun, ey?
| Re: Power handling and compression [message #43309 is a reply to message #43308] |
Tue, 09 December 2003 08:25   |
If you have two speakers with similar T/S specs, similar magnetic structures and distortion specs and similar cone structures and HF performance - If the only difference truly is power handling - then you have little reason to buy a speaker that handles 1000 watts if you'll be driving it with only 100 watts. But the truth is that a 1000 watt speaker is probably going to be superior in more ways than just power handling; The price commands superior performance. If one were comparing two speakers that were the same in all other respects, one would gain very little using one designed to handle significantly more power than is needed. But most of the time, expensive drivers from good manufacturers deliver more than just improved power handling. Compression specifications are sometimes provided by manufacturers. Typically, compression specs are in the form of derated output in dB at certain power points, often 1/10th power, 1/2 power and full power. Compression and thermal and mechanical limits are the penalties of overpowering a driver. What you'll see is that compression is usually less than 1dB at 1/10th power, and has risen to 2-4dB at 1/2 power. By full power, the best speakers suffer more than 3dB loss due to thermal compression, and most compress more than that, often 4-6dB or more. T/S specs are also affected as the driver enters compression, so its filter characteristics change as a result. This is a valid reason for operating a speaker below 1/4 to 1/2 of its rated power limits - To improve performance by keeping its parameters consistent. But I probably wouldn't suggest that operation below 1/4 power should be imposed, even for the most quality conscious.
| Re: Power handling and compression - Reprise [message #43764 is a reply to message #43307] |
Mon, 26 January 2004 08:19   |
Dean Kukral
Messages: 177 Registered: May 2009
Master |
Is the first paragraph of this post correct???? Should it not say "Compression is greater as average power is increased?" The same pro system in a home theater is not likely to experience compression, even with very high power levels occurring from time to time, but in a rock concert it may well see compression. Either garman or I am confused about the results. If the voice coil heats up and compression comes into play, then both volume (maximum) and dynamic range are affected. Whether or not the effect on dynamic range is linear, I don't know. If maximum spl is reduced by 3dB, then spl should be reduced at every non-zero power level input by some value less than 3dB but greater than zero. This is what is meant by "dynamic range," isn't it? If the effect turns out to be linear, then there is no real effect on the music, except that it is not as loud.
