Home » Sponsored » Pi Speakers » suggestions for premium stage 4 pi centre
suggestions for premium stage 4 pi centre [message #43143] Fri, 21 November 2003 07:06 Go to next message
drguayo is currently offline  drguayo
I'm going to build a premium stage 4 pi but wish to make it as short as possible. The standard size will cut in front of my projection screen - standard size is 26x18x14
I was thinking I'd make it 18" high and put the horn horizontally beside the woofer - so the box would be about 18 x 34 x 14 . I can enlarge the port for the extra volume but does anyone see issue with the horn centered with the woofer?
thanks
craig
Re: suggestions for premium stage 4 pi centre [message #43152 is a reply to message #43143] Sat, 22 November 2003 08:50 Go to previous messageGo to next message
finalized plans for centre premium stage 4 pi.
Kilomax 15 on left - Peavey CH-3 on right - port under horizontal horn position
| | || Horn
| + | Centre of Kilomax
| | | | Port
Height = 18
Width = 36
Depth = 13.5
help with port size? and whether this positioning of port will work?
thanks everyone
Craig.
repost with diff picture [message #43153 is a reply to message #43152] Sat, 22 November 2003 08:59 Go to previous messageGo to next message
|............................|.........................|| Horn
|...............+....................................| Centre of Kilomax
|................................|..........|..........| Port
Height = 18
Width = 36
Depth = 13.5
thanks everyone
Craig.
Layout Notes [message #43155 is a reply to message #43153] Sat, 22 November 2003 10:38 Go to previous message
As long as the chamber volume is the same, make the port the same size. As for layout changes, see the following:
Previous Topic: Deltalite 15
Next Topic: More fooling around with the KSN-1038
Current Time: Sat Nov 14 15:53:26 CST 2026
