Home » Sponsored » Pi Speakers » Do I have to use the PSD3003 with 18" drivers?
Do I have to use the PSD3003 with 18" drivers? [message #42870] Sat, 01 November 2003 04:48 Go to next message
drguayo is currently offline  drguayo
Would they work with the Omega 15" using the 800 hz crossover? and which horn do I then use?
thanks
craig.
Re: Do I have to use the PSD3003 with 18" drivers? [message #42872 is a reply to message #42870] Sat, 01 November 2003 10:49 Go to previous message
There's no reason why you have to use it with an 18" woofer, but one of the big advantages of going with a larger CD is a lower crossover frequency, which means you can use a larger diameter woofer with more displacement to fill in the bottom end. The other mode of thinking is to impliment them like you would a 1" exit compression driver and reap the benefits of reduced IM distortion and more potential from the larger driver.
Adam
Previous Topic: Two Pi Towers are HUGE!
Next Topic: How to downsize a cabinet's volume?
Current Time: Sat Nov 14 15:41:03 CST 2026
