Home » Sponsored » Pi Speakers » Horn advice
Horn advice [message #42689] Tue, 14 October 2003 08:11 Go to next message
Andrewbee is currently offline  Andrewbee
Hello Wayne,
I would like to try a pair of your horns. My room is 15'W X 37' long.
I do not want to "rock out" but want good bass down to ~40 cycles.
I plan to use a Fostex driver on a open baffle from ~ 100 cycles up and to bi-amp. I will be seated ` 20 feet from the speakers
Which set of horns your horns would you recommend and with which drivers?
Thanks
Andrew
Re: Horn advice [message #42699 is a reply to message #42689] Tue, 14 October 2003 20:38 Go to previous messageGo to next message
What's your budget and amplification? Does your room have corners suitable for cornerhorn loading at one of the 15' ends? If so, I'd be inclined to put JBL 2241's in a π cornerhorn configuration at each corner.
Re: Horn advice [message #42707 is a reply to message #42699] Wed, 15 October 2003 05:31 Go to previous messageGo to next message
I would rather stay South of 1K.
I have an AKSA 55w/ch that has killer bass control as well as an old Carver with ~ 150w/ch
Yes.
Okay, so which corner horns would you recommend and why?
Also any reason for a 18" as against a 15"? Is it because the room is so large?
When i think of a 18" its huge. I have to put my bigscreen tv between the corners as well. I should have told you that before.
Thanks
Andrew
Re: Horn advice [message #42716 is a reply to message #42707] Wed, 15 October 2003 17:26 Go to previous messageGo to next message
Those amps will work great with seven π cornerhorns with 2241's. If you'd like, I'll send you the plans. The basic cabinet dimensions are described in the post called "seven Pi-18 cabinet dimensions."
Re: Horn advice [message #42724 is a reply to message #42716] Thu, 16 October 2003 05:28 Go to previous messageGo to next message
Yes thanks, is it possible for me to get both sets of plans? The 18" & 15".
Thanks Wayne
Andrew
Re: Horn advice [message #42726 is a reply to message #42724] Thu, 16 October 2003 07:20 Go to previous messageGo to next message
Please send me your E-Mail address and I'll send you the plans.
Re: Horn advice [message #42728 is a reply to message #42726] Thu, 16 October 2003 11:30 Go to previous messageGo to next message
ajbrandon(at)yahoo(dot)com
Thanks
You've got mail! [message #42733 is a reply to message #42728] Thu, 16 October 2003 21:58 Go to previous messageGo to next message
Re: You've got mail! [message #42735 is a reply to message #42733] Fri, 17 October 2003 13:40 Go to previous message
Got it Thanks!
Previous Topic: Theater 3 Pi plans
Next Topic: Great Tube Art
Current Time: Sat Nov 14 15:40:51 CST 2026
