Home » Sponsored » Pi Speakers » JBL 2440
JBL 2440 [message #42546] Tue, 23 September 2003 06:01 Go to next message
rpstephen is currently offline  rpstephen
Hi: I would like to put together a speaker system for a friend using JBL 2440 drivers. LX5 xovers, and 2235 woofers and need recommendations for a midrange horn suitable for 500hz. Also looking for enclosure suggestions & tweeters.
Thanks,
Stephen
Re: JBL 2440 [message #42547 is a reply to message #42546] Tue, 23 September 2003 07:32 Go to previous message
You can use Martinelli or Edgar horns for your 2440's - Both are wood horns that sound great and are popular and attractive. If you are working with a budget, there are some plastic horns that will work very well for you too.
For the 2235's, PiAlign recomends a 4.0ft3 bass-reflex cabinet tuned to 30Hz. That would be my suggestion.
Previous Topic: Newbie . . . needs help . . .
Next Topic: Unfinished 2-Pi Towers FS in MN
Current Time: Sat Nov 14 15:42:04 CST 2026
