Home » Sponsored » Pi Speakers » Madison Knight 10" in SpeakerBox says 366L right?
Madison Knight 10" in SpeakerBox says 366L right? [message #41908] Sat, 12 July 2003 18:10 Go to next message
-3db is currently offline  -3db
I am about to cut wood, and I am a little stuck with PiAlign.
I assume I have to use a pre-set speaker name, and the associated file in order to run PiAlign. Is this right. I've taken the T/S from Madison's site for the Knight 10", and this is what I get:
Qts=.578
Qes=.599
BL=13.89
Re=10.4
Xmax =4mm
eff=95db/1w
200w
I'm not sure if this is all, but the reflex box comes out at 366L, 36hz
So, I'm xover at 90 hz to subs, so I think I am going to take the 260L aperiodic options.
'does any of this sound correct.
Thanks for your help to a newbie.
Sincerely,
-3db
too big
Re: a little help [message #41909 is a reply to message #41908] Sat, 12 July 2003 19:34 Go to previous messageGo to next message
366 liters for a 10" driver? oooo.... thats really big
As you go through pi aling enter the following fields
description= anything you want to call it
Type= M
lo cut= 50 (if you have 70hz sub 50 would be good)
hi cut= press enter for no entry
Eff= spl 1w/1m
power= watts max
impedance= Re (4,8,16 might get you close)
quantity= number of drivers per enclosure
for pi align you need to know from the t&s parameters
Vas this will be the VAD input (must convert to Cubic Feet)
Qts 1 devided by the Qts will be the QD input 1/.578=1.7301
Fs this will be the FD input
Enclosure type= B ( for bass reflex)
Port= C / cylinder R / rectangle
you now have all the dimensions and volume in cubic feet acording to pi align.
Bill
Thanks Bill: I will try these numbers before cutting. nt [message #41911 is a reply to message #41909] Sat, 12 July 2003 22:37 Go to previous messageGo to next message
nt
Re: Madison Knight 10" - Can you post a link to T/S parameters <nt>? [message #41913 is a reply to message #41908] Sun, 13 July 2003 10:02 Go to previous message
Previous Topic: JBL2226H+MAC40s+large room=Kick ass
Next Topic: Pi theater 3 or 4 and Adire 12.1
Current Time: Sat Nov 14 15:29:13 CST 2026
