Home » Sponsored » Pi Speakers » A question about speaker impedence ratings
A question about speaker impedence ratings [message #41860] Thu, 10 July 2003 00:04 Go to next message
I suppose this isn't a very smart question, but I'm a little uncertain and maybe somebody could smarten me up a bit.
If I use a parallel crossover for an 8 ohm woofer to an 8 ohm tweeter at 1KHz, first order Butterworth, the cap is 20 microfarads and the inductor 1.27 mH, each of which conveniently have impedances of 8 ohms. Consequently, I get a "series added" impedance for the system of 8 ohms.
But it seems that if I want to use another topology or crossover point, I'm going to have a hard time summing all impedances to 8 ohms, especially if my goals include suppressing resonances, padding down one driver to level match the other, compensating for impedance peaks with a Zobel, etc...
So I guess what I'm wondering is, overall, is it a happy coincidence that most crossover/driver system impedances sum to approximately 8 ohms? Or are speaker impedance ratings of "8 ohm" kind of wildly optimistic?
An answer about speaker impedence ratings [message #41868 is a reply to message #41860] Thu, 10 July 2003 09:39 Go to previous messageGo to next message
Advertised impedance is a sort of an averaged value. The impedance rating of loudspeakers is an approximate value, and is what you can usually expect in the midband of each subsystem. The crossover prevents each driver from loading the system except in its passband, so the system impedance curve looks much like the individual impedance curves of each of its drivers, connected by a transition region between each. To know overall system impedance as a function of frequency, you can either measure at several frequency points or you can model the loudspeaker circuit with Spice.
Re: An answer about speaker impedence ratings [message #42244 is a reply to message #41868] Thu, 21 August 2003 07:26 Go to previous message
john is currently offline  john
Can I than alter the impedence by, say, hooking up a resister in series? I'd like to slightly modify mine from 6-ohm to 8-ohm
Previous Topic: alternative speakers for Ten Pi
Next Topic: Plan request
Current Time: Sat Nov 14 15:41:38 CST 2026
