Home » Sponsored » Pi Speakers » 4 Pi Construction Question
4 Pi Construction Question [message #41815] Sun, 06 July 2003 18:15 Go to next message
I'm closing in. Five sides of the cabinets are biscuited and glued, internal stiffeners and fronts are cut, so the next task is to prepare appropriate cutouts for the drivers and ports.
One question: should the tweeter horns be recessed into the front baffles so they mount flush?
Re: 4 Pi Construction Question [message #41817 is a reply to message #41815] Sun, 06 July 2003 19:42 Go to previous messageGo to next message
Unless you really, really want to do it for style. It's not necessary and in fact there are a lot of high end studio monitor's with built in horns where the horn protrudes from the baffle. Even the flat front horns wont see much difference in response unless you are really pushiing the horn to cut off frequency. This is not the case with the 4pi crossover.
Bill
Re: 4 Pi Construction Question [message #41827 is a reply to message #41817] Mon, 07 July 2003 16:51 Go to previous message
Thanks, Bill. I'm feeling lazy and was looking to avoid the extra step unless it adversely affected the response.
Previous Topic: Theater Pi 4 bass response
Next Topic: Crossover values for Drivers with different Impedance??
Current Time: Sat Nov 14 15:30:27 CST 2026
